* * * * - 6 Голосов
Прошивка Navi 600 в Navi 900
Сообщений в теме: 7360
#4021 Амбр
  • Cообщений: 32 873
Отправлено 19 Октябрь 2015 - 16:57
Mew.tu,
Is it only one file that you have to Change? if so which one?
No, few files in other cataloges.
If i want to update to 2.08 must i use two steps?
If you have 600 up to 900 Navi v181, you just need write a new v208 firmware. But, v208 have a reason if you have new navigation maps 14/15.
is that right?
Yep )
#4022 Mew.tu
Mew.tu
  • Cообщений: 15
  • Автомобиль: Mokka
Отправлено 19 Октябрь 2015 - 17:19
Am6P
Okay Thank you again.
Yes i know that 2.08 is necesarry for 14/15 Map.
So i will skip the V2.0.
Things will get clearer step by step.
But another Question:
For updating from 1.81 to 2.08 do i also need the V2.08 Iso or is it enough to change the theme to 2.08.
I´ve already downloaded the V2.08 iso.
So until now i think i had to do these 3 Steps:
1.) Change the 600 to 900 using your USB/ISO getting 1.81.
2.) Update the "new 900"with the original "GM V2.08 Iso" to 2.08
3.) Update the theme to 2.08 using yoúr theme.
Or can i skip 2.) ??
Will using the original V2.08.Iso Change it back to Navi600?
Questions over Questions.
#4023 simus
simus
  • Cообщений: 43
  • Автомобиль: Insignia OPC
Отправлено 19 Октябрь 2015 - 17:42
yes you can =)
No. For changing to navi600 you need "downgrade firmware".
#4024 Mew.tu
Mew.tu
  • Cообщений: 15
  • Автомобиль: Mokka
Отправлено 19 Октябрь 2015 - 17:54
Okay Thanks!
So using an original Iso will only update the "changed 600" to a "factory clean 900"?
Once i´ve used the "Magic Upgrade Software" ist will always act as a real 900 until i use a "downgrade Software"?
#4025 Амбр
  • Cообщений: 32 873
Отправлено 20 Октябрь 2015 - 10:08
Yes
Yes
#4026 Dedrich
Dedrich
  • Cообщений: 638
  • Автомобиль: Opel Astra J 5d 1.4 turbo, AT6, Cosmo, AFL, NAVI
Отправлено 20 Октябрь 2015 - 13:02
Проснулся интерес и к темам со стандартными значками POI.
Выкладываю пока одну тему, универсальную. Можно ставить как на NAVI 600, так и на NAVI 900.
Дистанции уведомлений 200 и 600 м. Полупрозрачные панели уведомлений и имитация полупрозрачности регулятора громкости.
В 600 варианте использования не предусмотрена загрузка POI. Значки стандартные и только тема. Измененные значки только в 900 варианте загрузки в ГУ.
С измененными значками POI
Red_Theme 4_2 rus POI v.200 https://yadi.sk/d/DEg5FNHLjrwdv
Со стандартными значками POI для наших гостей - западных партнеров
Red_Theme 4_2 stand POI v.200 https://yadi.sk/d/9hyDlCxEjrwcy
Папка превью https://yadi.sk/d/wBWvtOQbLYSX9
Сообщение отредактировал Dedrich: 20 Октябрь 2015 - 13:26
#4027 hengehog
hengehog
  • Cообщений: 17
  • Автомобиль: meriva B 1.4T
Отправлено 21 Октябрь 2015 - 14:57
Ребята, а у меня абсолютно дурацкая проблема. Скачала прогу, зарегилась на mapcam, хочу скачать speedcam. Прога пишет что нужно либо для Garmin либо для PocketGIS. а у меня в выборе типа навигатора на сайте таких не выдает(((( что делать?куда бежать?))
#4028 Амбр
  • Cообщений: 32 873
Отправлено 21 Октябрь 2015 - 16:44
hengehog, PocketGIS появляется при наличии платной подписки. Если не хотите платить, скажите, какой регион Вам нужен, скачаю для Вас.
#4029 hengehog
hengehog
  • Cообщений: 17
Отправлено 22 Октябрь 2015 - 08:23
#4030 Амбр
  • Cообщений: 32 873
Отправлено 22 Октябрь 2015 - 11:22
hengehog, https://yadi.sk/d/CILoNvq8juyRb
#4031 Mew.tu
Mew.tu
  • Cообщений: 15
  • Автомобиль: Mokka
Отправлено 24 Октябрь 2015 - 15:47
Hello my friends,
now i have a great Problem.
I flashed the navi, with a "selfmade" V2.08 and now it resets it self every 60 sec.
Do you have any idea how i can flash it new with a working Firmware?
Is there a chance to get it into the bootloader mode to use a CD?
#4032 Dedrich
Dedrich
  • Cообщений: 638
Отправлено 24 Октябрь 2015 - 16:26
You had only to take one of our version themes of the 208 and transfer from there files images 11.uli, images 22.uli, registries.uli. Within the file resource.bin to replace the night sky in stock (original) firmware v.2.08.
What and how you changed?
I mean that for example 200 version files can not be copied directly into the firmware 208.
Try to pull out the SD card and insert it again, and even better to try another card, preferably version above.
I did not knowingly put a theme Red_Theme 4_2 stand POI v.200 https://yadi.sk/d/9hyDlCxEjrwcy
to be seen in the analysis of how and what changed.
Сообщение отредактировал Dedrich: 24 Октябрь 2015 - 16:37
#4033 Mew.tu
Mew.tu
  • Cообщений: 15
  • Автомобиль: Mokka
Отправлено 24 Октябрь 2015 - 16:49
Because the unit is resetting every 30 sec there is no Chance to Flash an other theme.
Is there any chance to get into the bootloader and boot from CD?
#4034 Dedrich
Dedrich
  • Cообщений: 638
Отправлено 24 Октябрь 2015 - 16:58
The loader can be accessed only during the transition from 600 to 900. Now it is not.
Try the original disc 208. If the remaining time will start loading, you get. Another wrote to the PM.
To create your own firmware, it is necessary to open the files of the original firmware utility unpack and edit or inside the folder its contents pour from the unpacked file from another theme here. Then pack again.
Сообщение отредактировал Dedrich: 24 Октябрь 2015 - 17:11
#4035 Mew.tu
Mew.tu
  • Cообщений: 15
  • Автомобиль: Mokka
Отправлено 24 Октябрь 2015 - 17:10
But how can i start update from CD?
#4036 Dedrich
Dedrich
  • Cообщений: 638
Отправлено 24 Октябрь 2015 - 17:16
Well, at least try?
Сообщение отредактировал Dedrich: 24 Октябрь 2015 - 17:17
#4037 Mew.tu
Mew.tu
  • Cообщений: 15
  • Автомобиль: Mokka
Отправлено 24 Октябрь 2015 - 17:29
Thats what i do before i asked!
I did not found a way.
#4038 Dedrich
Dedrich
  • Cообщений: 638
Отправлено 24 Октябрь 2015 - 17:40
Try from USB flash cards. Copy the folder DNL into flash card from the disk and try to load.
About Maps wrote above. There are no other options.
Reflash boot loader normally do not get. It is necessary to remove the device, and directly on the electronic board, it is necessary to reflash memory.
В общем пипец уже, а как дышал! Похоже не грузятся 11 и 22 файлы.
Сообщение отредактировал Dedrich: 24 Октябрь 2015 - 18:03
#4039 Mew.tu
Mew.tu
  • Cообщений: 15
  • Автомобиль: Mokka
Отправлено 24 Октябрь 2015 - 18:05
Also tried that. Time is to short. its only 30 sec before rebooting.
#4040 Dedrich
Dedrich
  • Cообщений: 638
Отправлено 24 Октябрь 2015 - 18:09
And without a SD card, too, goes to reboot? I mean again after the first reboot.
The SD card has a navigation control module. It's like a piece of the system. If it does not fit in with the system, it is possible the system tries to catch it after a reboot.
Сообщение отредактировал Dedrich: 24 Октябрь 2015 - 18:17
