* * * * - 6 Голосов
Прошивка Navi 600 в Navi 900
Сообщений в теме: 7360
#4341 chawks
chawks
  • Cообщений: 12
  • Автомобиль: vauxhall insignia
Отправлено 19 Февраль 2016 - 17:44
Hi friend,
I have just gone through the upgrade using USB and CD data that I know works...when I insert the USB it does not fail at 80%, it go's straight 100% then restarts. When I check the diagnostic page it shows I am now running /g_mpeu10? Which I believe is Navi 900. But there are no 3D maps ???
During the upgrade it did not fail at 80% so I did not insert CD and it did not boot into the boot up screen like it did when I very first upgraded. I really am at a loss as to what has happened??
#4342 Dedrich
Dedrich
  • Cообщений: 638
  • Автомобиль: Opel Astra J 5d 1.4 turbo, AT6, Cosmo, AFL, NAVI
Отправлено 19 Февраль 2016 - 18:07
Interested in what version of firmware Red theme.
Now, after the rollback in the 600, you must have version v181. That's right, re-flash the firmware with already runs without stalling in the boot loader.
But after this procedure is necessary to run the native navigation map SD 600. Check settings NAVI presence 3d mode. Perhaps your new card is required v200 or 900 v 208. Therefore I ask which version was the Red theme.
This SD card 900 is necessary to postpone, to return the 3d mode using the old map.
Сообщение отредактировал Dedrich: 19 Февраль 2016 - 18:11
#4343 chawks
chawks
  • Cообщений: 12
Отправлено 19 Февраль 2016 - 18:09
Just to update further, I have now installed new themes with no problems at all, this I thought you could only do on upgraded Navi 600...so I am obviously running 900 but with no 3D maps..
Are the 3D maps on the SD card or part of the upgrade software ????
#4344 Dedrich
Dedrich
  • Cообщений: 638
Отправлено 19 Февраль 2016 - 18:18
I think the firmware function. And no there 3d. Just a distortion of the plane in perspective.
but the card has a control module navigation. He provides after flashing and starting the navigation update.
Poor compliance with this module firmware may be the cause of this.
A similar incident I had. The cause was not high quality USB flash drive.
Сообщение отредактировал Dedrich: 19 Февраль 2016 - 18:31
#4345 mike6688
mike6688
  • Cообщений: 2 636
Отправлено 19 Февраль 2016 - 18:35
chawks
1. First, the firmware 1 from CD.
2. Then the second firmware from USB.
3. Insert SD (old for NAV600 12-13 or 13-14).
4. Then again the firmware 1 from first CD.
If 3D does not appear in the menu, repeat step 2.
Only in this way!
Сообщение отредактировал mike6688: 19 Февраль 2016 - 21:39
#4346 Dedrich
Dedrich
  • Cообщений: 638
Отправлено 19 Февраль 2016 - 18:38
And uses a different USB flash drive. Not all flash drives are the same. The firmware lot of small files. Therefore require flash to easily cope with the task of reading and writing small files is not worse than large.
When using our themes, choose the title with a prefix _st. These themes with standard POI icons, designed for European users.
Сообщение отредактировал Dedrich: 19 Февраль 2016 - 19:01
#4347 chawks
chawks
  • Cообщений: 12
Отправлено 19 Февраль 2016 - 20:32
Hi Mike,
thank you for this below....I assume I do this after downgrading back to Navi 600 ???
If so the instructions below are the very opposite of the normal upgrade to Navi 900 ??
Thanks
Chris
mike6688 Joined Today, 18:35
chawks
4. Then again the firmware 1 first the CD from.
Only in the this way!
#4348 mike6688
mike6688
  • Cообщений: 2 636
Отправлено 19 Февраль 2016 - 20:53
OK! Yes, after a downgrade of up to 600.
See this: #17
and this: #1
and this: Flashing the standard navigation system Navi 600 to Navi 900 (for Opel (Vauxhall), Chevrolet and other GM cars)(ENG)
#4349 mike6688
mike6688
  • Cообщений: 2 636
Отправлено 19 Февраль 2016 - 21:33
У нас, в первом посте, в п.п. 5 и 7 из-за предложения извлекать SD карту перед прошивкой, БОЛЬШАЯ путаница получается! Нужно отредактировать так, что бы не вводить народ в заблуждение.
на пример:
5) Вытаскиваем все флешки, диски и вставляем наш диск с изначальной прошивкой. Соглашаемся на перепрошивку (даже если предложенная версия ниже имеющейся). ВНИМАНИЕ!!!! Карточку SD необходимо вытаскивать не до, а после предложения системы прошиться, так как если ее оставить, в ряде случаев (крайне редких), это может привести к повреждению хаба USB/SD из за особенностей его электронной развязки, в результате локального перегрева.
7) Вытаскиваем все диски из мафона, sd-карту с картами навигации и вставляем нашу флешку. Если ничего не происходит, вставляем в слот SD с картами и после появления сообщения перепрошиться, извлекаем её и подтверждаем предложение прошиться.
Пункт 11, отредактировать так:
Вставляем еще раз юсб-флешку, Если ничего не происходит, вставляем в слот SD с картами и после появления сообщения перепрошиться, извлекаем её и повторяем пункт 5, в итоге прошивка должна встать.
Сообщение отредактировал mike6688: 19 Февраль 2016 - 21:35
#4350 mike6688
mike6688
  • Cообщений: 2 636
Отправлено 19 Февраль 2016 - 21:46
chawks
If 3D does not appear in the menu, after paragraph 4, then repeat paragraph 2 .
Give the link where you bought the navigation map for NAVI900.
Сообщение отредактировал mike6688: 19 Февраль 2016 - 22:22
#4351 chawks
chawks
  • Cообщений: 12
Отправлено 19 Февраль 2016 - 23:37
Hi Mike, its late now in the UK so I am going to get on and do this again in the morning. I have downloaded the files again, I have burned the CD at x1 speed successfully, and transferred the other dnl files to a quality fat 32 formatted USB...I will downgrade first thing in the morning and go through the upgrade again.
The problem I have been having is when installing the software off the USB it doesnt fail at 80%, it just go's to 100% then restarts...
I no longer have the 900 SD card I returned it to the seller on eBay..
http://www.ebay.co.u...~AAAOSwQoFWOTLQ
#4352 chawks
chawks
  • Cообщений: 12
Отправлено 20 Февраль 2016 - 14:56
Hi again my friend....
Well I have done everything you suggested, all from rebooting my Navi back to 600...followed you instrctions to the letter...burned a new CD at X1, bought a new Toshiba USB this morning formatted FAT32, I have just completed the install.......and nothing, still no 3D maps ???
The photos are showing the map data before and after install...but the strange thing is I can do all the theme updates without any problem whatsoever.....[attachmentid=127484]
Image 2308 shows the Navi 600 prior to upgrade..
Image 2309 shows the Navi 600 upgraded....as per your instructions....
#4353 mike6688
mike6688
  • Cообщений: 2 636
Отправлено 20 Февраль 2016 - 16:09
chawks
Please, show picture of settings menu map mode (4 on my pic).
Choose navigation mode--> select Settings navigation (press ring)--> Navigation options--> Map options--> Map mode.
Сообщение отредактировал mike6688: 20 Февраль 2016 - 16:11
#4354 chawks
chawks
  • Cообщений: 12
Отправлено 20 Февраль 2016 - 20:04
Mike...
Brilliant news, I have gone through your process once more and it was successful, all back up and running...3D maps the lot.
Thank you so much my friend....
Chris
#4355 lpm61
lpm61
  • Cообщений: 5 338
Отправлено 20 Февраль 2016 - 20:12
А спасибо не кликнул smile.gif Бриллиантовый... smile.gif smile.gif (шютка) Надо кнопку переименовать - спасибо/thanks !
#4356 mike6688
mike6688
  • Cообщений: 2 636
Отправлено 20 Февраль 2016 - 20:15
#4357 Сержпитер
Сержпитер
  • Cообщений: 2 559
Отправлено 20 Февраль 2016 - 20:20
mike6688, не за что. Надо было просто попросить.
Давай еще туда же английскую версию текста запилим?)))
chawks,
Dear, for say "fhanks" use the blue button Изображение in the post.
#4358 Dedrich
Dedrich
  • Cообщений: 638
Отправлено 20 Февраль 2016 - 20:25
А на своем сайте ему предлагали скинуть клемму аккумулятора. Типа кровопускания в старину.
http://www.insignia-...showtopic=23630
#4359 chawks
chawks
  • Cообщений: 12
Отправлено 20 Февраль 2016 - 20:26
Mike...
Chris
#4360 Сержпитер
Сержпитер
  • Cообщений: 2 559
Отправлено 20 Февраль 2016 - 20:30
chawks, please don't forget for copyright laws. ))) in other forums please leave a link. Thank you!
